LT1/LT4 Tech 1993-1997
head work
Old Jan 7, 2009 | 12:15 AM
aightball87's Avatar
Default head work
i want to build my heads. how should i have them ported? (intake/exhaust) should i port out the valves or not? this is a stock cam for now and it has an adjustable fuel pressure regulator from aeromotive. do i need new injectors? the stock ones are 24lb.should i shave them too while i am at it.
Old Jan 7, 2009 | 08:14 AM
whammer3024's Avatar
ROTM Winner
Default RE: head work
porting your heads won't gain you much HP on the stock cam. if you're pulling the heads anyway, you might as well throw a cam in there. save some time and do the work once. if you do a heads and cam package then yes you will need bigger injectors
Old Jan 9, 2009 | 01:02 PM
ok what size cam would you suggest for a street application? i was going to get one sooner or later anyways. ive already got the roller rocker at my house. they are 1.6s i was going to wait on the springs until i decided on a cam. i also have some new pushrods fromm gm performance. let me know what kind of setup you would do on a budget.
Old Jan 9, 2009 | 03:20 PM
ROTM Winner
depends on the budget...and goals for the car
Old Jan 9, 2009 | 04:43 PM
To get good results the heads, cam, compression, intake, exhaust,and displacementhave to be matched to each other. You have to decide how much power you want, and how you want to useyour car. If you plan to drive the car regularly on the street, the engine has to be built differently than one that is going to live on the racetrack.
Old Jan 9, 2009 | 05:28 PM
ROTM Winner
yup...that's what i was trying to say. talk to whoever you want to port your heads about all of that and they can match everything perfectly to what you desire
ScottD
Nov 10, 2009 08:15 PM
carguylt1
Aug 6, 2009 05:03 PM
350rs
May 29, 2008 12:49 PM
350rs
May 21, 2007 10:05 PM
dzroc
Jun 13, 2006 10:42 PM
