LT1/LT4 Tech 1993-1997
Has anybody swapped a 10 bolt for a 8.8 rear end
Old Aug 2, 2011 | 04:45 PM
grabbem88's Avatar
Default Has anybody swapped a 10 bolt for a 8.8 rear end
I was curious if anybody has or know what it takes to put one up there
Yeah a 12 bolt or a 9 inch is nice but for the price you can have a 8.8 behind a camaro for less than a grand and never worry about it Grenading plus no parasitic loss compared to a 9 incher
Old Aug 3, 2011 | 12:01 AM
Buffalo02Z28's Avatar
Its been done before. Go check LS1 Tech for more info on the topic.
Old Aug 3, 2011 | 08:45 AM
grabbem88's Avatar
I will thanks but do you remember the post or link?
Old Aug 3, 2011 | 09:08 AM
Cheeks's Avatar
August 2011 ROTM
already finished my 8.8 - LS1TECH
its doable, if you have the facilities to do it, otherwise, its best just to buy a 9 inch
Old Aug 3, 2011 | 03:59 PM
grabbem88's Avatar
Damn I was hoping for more detail but I think I got an idea
Old Aug 3, 2011 | 06:02 PM
Cheeks's Avatar
August 2011 ROTM
essentially what you're going to have to do is cut all the brackets off your 10 bolt, weld them in the exact same spots on your 8.8. Then narrow the axle tubes, weld on teh correct axle ends for the chevy brakes then you're set.
We did this when we made my 9 inch for my car, not as easy as you think. Plus, don't forget you need to figure out a mounting system for your torque arm on teh rear end housing
Old Aug 3, 2011 | 06:50 PM
grabbem88's Avatar
So it be less of a headache getting a 9inch?
I figured it wasn't as easy as I think but I have built enough mud trucks that I think I can muscle this task. It's all about placement fitment and geometry
MusicMan
Sep 29, 2008 06:25 PM
350rs
Sep 12, 2008 11:35 AM
srich1207
Mar 4, 2008 03:49 PM
mcge383
Nov 7, 2006 09:56 PM
cabowaboz28
Jul 29, 2006 01:58 AM
