got a couple rebuild questions
Boy, you sure like opening cans o' worms don't you? ![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
Just be aware that your engine could have enough cylinder wear (bowed in the middle, running on a bias, etc.) to where the block might need to be bored oversize to true it back up. That means getting new pistons, so don't go buying new rings until you get the block checked over at the machine shop for any "surprises".
I've found sbc engine bearing and gasket sets around before that were good prices on ebay but be careful what you buy on there. You might wanna just look for a rebuild kit at northern auto parts or somewhere similar. I've heard Northern has good kits and the kits can even be upgraded with hotter cams,different piston, etc. Im not sure if they have lt-1 kits but it might be worth it to look. Btw as far as their cams go im not sure how good there performance ones are but ive heard good things about their kits. northernautoparts.com
Here is a kit from northern for 92-96 LT-1 excluding corvette. Chevy 350 LT1 1992-1996 VIN Code P exc corvette
this is just bearings rings and gaskets.
So I pulled the motor apart today the block looks great bearings had some wear on them especially cylinder 2 the cylinders look good a few scratches I took a piece of round bar and cut it to the bore and spun it around inside seems good and round but I'm still getting it looked at... now the piece of metal that holds the lifters down can I drill some holes in it for oil drain the cars only ran for 2-3 hours and there's already some thick oil there
got the block back today the guy told me "you have a really good chunk of metal here" lol i guess its not so funny when you cant hear it redneck... anyways now im just waiting to get paid so i can get the parts
