LT1/LT4 Tech 1993-1997
Gears
Old Jan 31, 2007 | 02:46 AM
94Ztwo8's Avatar
Default Gears
I just picked up a set of 3.73's and im going to eventually have them installed. I was just wondering what im going to need?
Old Jan 31, 2007 | 01:05 PM
Default RE: Gears
You'll need an installation kit, and depending on what gears you have now, either a new carrier or a spacer for the ring gear.
Old Jan 31, 2007 | 02:52 PM
shnormo's Avatar
Default RE: Gears
You're going to also need an arbor press to press in the new bearings and a brass free drift punch to take out the old races in the differential. You're going to need a new pinion seal, pinion nut, and pinion washer.
Old Jan 31, 2007 | 04:05 PM
Gentleman Jack's Avatar
Default RE: Gears
don't forget the new crush sleeve, torque wrench, big *** cheater pipe, dial indicator w/ magnetic base, marking compound, bearing splitter (to remove bearing from pinion when you have to change your spacers - you never get it right the first time). I'm sure I'm forgetting a few things. You don't need an arbor press for the bearing, just putit in the oven for abour 5 minutes and slide it on the pinion as soon as it comes out (don't forget the leather gloves). if you've never done it before, get someone who has to help you. setting up rear ends (properly) is an art. if you want to have a shop do it for you, expect to drop about $600.
Old Jan 31, 2007 | 05:13 PM
94Ztwo8's Avatar
Default RE: Gears
Ok thanks alot, I guess im gonna have to get someone to help me cause im not paying 600.
Old Jan 31, 2007 | 07:11 PM
Default RE: Gears
that's the going rate around here. I would look around your area to see if you can find something you might consider "reasonable" before opting to tackle this yourself, unless you just want the experience and "know how" under your belt.
sepadowd
Aug 4, 2011 07:59 PM
91camaro350
82-92 V8 Tech
Aug 5, 2010 10:28 AM
gfrench
Jun 19, 2010 10:16 PM
1bad96Z28
Jun 9, 2007 09:12 AM
