LT1/LT4 Tech 1993-1997
Gathering the pieces
Old Jan 31, 2014 | 06:04 PM
oldschool72's Avatar
I was already planning on upgrading my springs but are you saying I should be able to just use stock rockers or should I look for some self aligning 1.5s? What strength springs do you think would be good? or should I just call comp cams and talk to them about what they would suggest?
Old Jan 31, 2014 | 07:00 PM
I'm using patriot gold springs heres something i came across
Valve Spring Guide - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Old Feb 3, 2014 | 11:15 AM
What about the rockers? Were you saying I should be able to use stock rockers?
Old Feb 3, 2014 | 04:05 PM
you probably could, i would go with roller rockers and hardened pushrods. yep call comp cams and see what they say
Old Apr 29, 2014 | 07:14 PM
So whats the advantages or disadvantages to using self aligning roller rockers vs non self aligning roller rockers with guide plates? Just trying to decide which style rockers to use.
Old Apr 29, 2014 | 10:41 PM
i figured at high rpm with high lift the guide plates held the pushrods in place better. also like the smaller size of the rockers.
Old Apr 30, 2014 | 04:10 PM
The biggest concern I've heard with self aligning is if the valves started floating at high rpm then the rocker may come off the valve and cause some serious mayhem but idk bout that since the stock are self aligning. Theres a set of crane cams s/a rockers I could get for 70 but it looks like the rocker itself was wearing on the spring retainer instead of rolling on the tip.
Old Apr 30, 2014 | 05:24 PM
stock are made to go 5500 rpms. if your not planning on any 6500 shifts then your ok. i would shy away from used rockers that did not come off the engine your working on.
MrsLT1Pwrd
Mid West
Jul 26, 2011 10:08 PM
Chevelle Man
Nov 7, 2009 04:09 PM
