LT1/LT4 Tech 1993-1997
gas mileage is suffering... bad
Old Jan 19, 2010 | 02:38 PM
black95z28's Avatar
Default gas mileage is suffering... bad
1995 camaro z28 six speed. 3.42 gears.
when i first bought my car, and the summer after, i averaged to get 300 miles out of a tank, or usually about 20mpg combined highway and city, mostly city. over this winter, i average 200 miles out of a tank. this is killing me. is it because of the cold weather? i cleaned my k&n filter and that did not help. a 33% sudden drop off of a fairly fresh motor is not a good sign for me. any ideas of this sudden drop? thanks
Old Jan 19, 2010 | 02:46 PM
Do you let the engine idle for a while to let it warm up? Sitting still with the engine running gives you zero miles to the gallon, and affects your overall average. Also, some areas have a "winter blend" of gas that contains more ethanol than the summer blend (summer is usually 10%). A higher percentage of ethanol in the gas lowers your mpg's. Read the label on the gas pump, it tells how much ethanol is in the gas. If you don't like what you read, try a different gas station.
Old Jan 19, 2010 | 06:12 PM
robmnrd's Avatar
^ Truth.
The winter blend gas is a joke. >.< It seriously makes me mad because my average mileage usually drops from 22 to 18. :/
Old Jan 19, 2010 | 07:15 PM
scann it and see if the 02s or mas are acting up. could try an reset the computer by unhookin the battery for a while. scann first unhooking battery clears the codes.
marten
Dec 20, 2010 10:01 AM
jason7504
Apr 3, 2010 12:29 PM
chardchant122
Mar 10, 2010 10:14 AM
The Corvette Doctor
Jan 24, 2008 09:19 PM
The Corvette Doctor
Nov 15, 2007 10:42 PM
