LT1/LT4 Tech 1993-1997
fuel pump, maybe electrical?
Old Aug 21, 2012 | 07:33 AM
  #21
yes aa will have them. i used the plastic ones, i heard on here there are metal ones now that are better.
Old Aug 21, 2012 | 06:14 PM
  #22
bob97z28's Avatar
ok, i will buy one tom when the pump comes in. SO ive seen all the "how tos" on installing a fuel pump, but is there any tricks, or advice? I was going to use the shoebox write up to do it
Old Aug 21, 2012 | 06:20 PM
  #23
BasicConcepts's Avatar
Technical User
its pretty straight forward... are you getting just a pump or a whole new sending unit?
Old Aug 22, 2012 | 06:36 AM
  #24
bob97z28's Avatar
Old Aug 22, 2012 | 09:59 AM
  #25
Technical User
your going to have to crack the case of the sending unit open to install that pump. make sure you get an epoxy that will withstand being soaked in fuel forever, unless your near tokeland wa than craby can plastic weld it for ya ... i know you want to use that welder craby
Old Aug 22, 2012 | 03:06 PM
  #26
bob97z28's Avatar
bought metal clap thingy, got pump today. I guess ill use alot of duct tape on the case then? hahah ill do my best, if i fail, i will be ranting in bout 2 hours
Old Aug 22, 2012 | 03:09 PM
  #27
Technical User
metal clap thingy???
duct tape will NOT work, about 15 min in the tank and the sending unit will fall apart.
from the JB Weld FAQ page
Q: Is J-B Weld resistant to water and/or gasoline?
A: When fully cured, J-B Weld is completely resistant to water, gasoline, and about every other petroleum product or automotive chemical. For wet-surface or submerged water or gasoline repairs, see our J-B Stik or Waterweld product information.
Old Aug 23, 2012 | 02:21 PM
  #28
bob97z28's Avatar
i was joking, but i do have and issue. My fuel level sending unit is not the same one ive seen on the others lt1 pump instals, and i have 3 wires on it,, one in the bottom that connects to the unit, from the unit, and 2 on the top, 1 to the top wires and 1 to them pump. I have no clue where to put the extra black wire that came with the new pump
Old Aug 23, 2012 | 04:18 PM
  #29
bob97z28's Avatar
i just went for it,, she primed well, fired right up. What psi should i be running when priming, on, and WOT? Also how long can i drive it without the wiring harness? what could it hurt if i dont?
Old Aug 23, 2012 | 04:31 PM
  #30
Greg08's Avatar
I used seal all and some strong *** metal cord to lock the bucket back onto the bracket
