LT1/LT4 Tech 1993-1997
fuel pump, maybe electrical?
Old Aug 18, 2012 | 01:50 AM
bob97z28's Avatar
Default fuel pump, maybe electrical?
The other day, when i started my car, i noticed the fuel pump was super loud when it primed. Then when i started the car it was still loud. Its constantly humming louder than it ever has. I Changed the fuel filter, no change. It has no loss in power, it primes every time. When i was close to home, i went WOT to see if it was dying, but no difference in power at all. I did notice that when i do anything that draws electrical power like turning on ac or windows, the sound gets slightly quieter. Never stalled or not primed properly.
I have had minor electrical issues with the car, i found out i had bad battery terminals, but before that i was pulling some fuses. After i changed out the terminals and discovered a half way broken battery bracket, everything worked fine. But my fuel pump didnt start acting up until 2 days after that. I dont want to cut open my 'flap' or drop the tank just yet, i have a feeling its something simple. Any ideas?
Old Aug 18, 2012 | 07:45 AM
MKCoconuts's Avatar
You could do a fuel pressure test just to double check. Mines always been loud and I've never had a problem. Only time it ever gets louder is when I'm lower on fuel which is understandable seeing as the fuel cools the pump.
Old Aug 18, 2012 | 09:01 AM
bob97z28's Avatar
ill do one today
Old Aug 18, 2012 | 10:36 AM
Grandpaswagon's Avatar
The only time I really hear mine is when the little seperator panel between the "trunk" and the rear hatch is left down. With it down I can hear the pump all the time. With it up, I can barely ever hear it.
Old Aug 18, 2012 | 10:48 AM
fuel pump getting louder is a warning that fuel punp is getting tired. start planning on new fuel pump.
Old Aug 18, 2012 | 10:53 AM
jkeaton's Avatar
I don't hear my fuel pump at all. Mine must be stealth.
Old Aug 18, 2012 | 01:03 PM
It's an electric motor. Hearing it get progressively louder means the motor is on the way out. Be prepared for a failure.
Old Aug 18, 2012 | 07:56 PM
bob97z28's Avatar
so i did a fuel pressure test,40psi when priming and 35 at idle.
Old Aug 18, 2012 | 07:57 PM
bob97z28's Avatar
i have a feeling its somthing stupid, not the pump itself. I dont know what i can trouble shoot, any ideas? It has given mo no loss in function, or performance at all
Old Aug 18, 2012 | 09:51 PM
if the noise is coming from the gas tank and it goes away when the punp stops then its the pump. pump may go good for a year and may go good for a day. one in my truck went for a year makin louder and louder noise, i got tired of the noise so changed it.
