LT1/LT4 Tech 1993-1997
fuel pump
Old Aug 30, 2006 | 09:12 PM
kwest's Avatar
Default fuel pump
does anyone know if there is an access door under the carpet for changing the fuel pump on a 95 z28? I know some cars have them and im about to change mine and just thought it would make the job that much easier....
thanks,
kevin
Old Aug 30, 2006 | 10:28 PM
Default RE: fuel pump
There is no door, the official way is to drop the tank. However, many people cut their own door to avoid dropping the tank.
Old Aug 31, 2006 | 10:55 AM
sellc's Avatar
Anyone who cuts a hole in there camaro that is not a gutted race car is just a jackass! First of all that hole would have to be about 4 foot by 5 foot to even get the sender out of the tank and even then it would be tight!
The job is not as bad as everyone says but it is not something that the novice should tackle.
The rear end DOES NOT have to come out. All you have to do is drop the exhaust.
I have done loads of them. The older 86-92's are a little easier IMHO.
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
