LT1/LT4 Tech 1993-1997
fuel pump?
Old Aug 13, 2010 | 12:38 PM
EagleRex's Avatar
Default fuel pump?
Can I put a 95 trans am fuel pump on a 97 z28. Autozone tells me that the plugs are different. Is there a way to rewire it.make it work. Please help
Old Aug 13, 2010 | 05:01 PM
do you have the pump already, is that why you need to know? im not really sure, ive looked around and some pumps say they will work from 93 to 97 and some say only 96-97. so i would say that somthing is different and some of the pumps come with an adapter. also the aftermarket pumps were the ones that showed 93 to 97 so it may be the housing is different on the oem ones. oem come with the white plastic sump housing and aftermarket is pump only.
Old Aug 13, 2010 | 06:31 PM
What is a "transfer am fuel pump"?
Old Aug 13, 2010 | 10:46 PM
CNCman's Avatar
Here is the parts manual for 93 to 02 yrs Camaro but not sure about Transam.
http://www.z28.com/LyleA/93-02%20%20...s%20Manual.pdf
http://idownloadunlimited.com/server...%20manual&cr=1
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
