LT1/LT4 Tech 1993-1997
Fuel Pressuse
Old Apr 3, 2017 | 11:01 PM
buddy902's Avatar
Ok maybe i can get time to look at those things tommorow I keep it posted on what i find thanks
Old Apr 3, 2017 | 11:53 PM
is the shield still on the starter, should be a metal shield that mounts between the engine/exhaust and the starter to keep it from overheating. i use a aftermarket insulation wrap.
Old Apr 9, 2017 | 08:30 AM
buddy902's Avatar
Hello I did some checking yesterday and the shield is on the starter I did some wire chasing yesterday and noticed the fuel pump wire connector mounted on the rear floor pan just in front of the rear end that powers the fuel pump to be a little loose and burnt a little i may need to do something with that connector i dont like whats there i can wiggle it some and the fuel pump starts working again not sure if that is part of the problem but it is not helping matters
Old Apr 9, 2017 | 04:10 PM
fix it, lol. is the connector not connecting or the wire is lose and not connecting. if its the connector then you can bend the clip and sometimes it makes a tighter contact.
Old Apr 13, 2017 | 08:21 AM
buddy902's Avatar
Hello again I am trying to remove the hard pipe that has the schrader valve in it mine is leaking is there any way to remove this line i have been reading about tig welding a bung to the end of the fuel rail just wondering if this line can be removed easy or have to cut it out
Old Apr 13, 2017 | 09:26 AM
that holds the injecors in. you need to take the bolts out that hold it down and work it out. have you downloaded the shop manual yet.
Old Apr 13, 2017 | 09:28 AM
go here and click your year to download factory service/shop manual. https://www.mediafire.com/?40mfgeoe4ctti
Kendagenius
Feb 5, 2017 12:23 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
