Fuel injectors
#31
what exhaust do you have, borla with the block off plate is the only one i know of that has two pipes and can come out of one pipe. i thought you were looking at the spark plugs to tell it was rich on the one side.
#32
I will have to look to see what exhausr it is. but the H pipe is a custom one if that matters. looking at the plugs well they where all black. It threw me when i remembered it was tru duals. So why is all the smoke coming out of 1 side of the exhaust? stopped up maybe?
#34
So I guess I should call that a Y. Thanks
#36
wonder y the smoke is coming out of 1 side of the muffler?
#37
is the exhuast noise coming out of that side more than the other? it may be that side has more flow. look in the how to and faq sticky at the top of the 4th gen section for how to test evap
#38
All that was done away with. i have 2 fuel pumps all steel braided lines come from each pump. 1 pump is strictly for nos use.
#39
my plugs foul out sooner or later. once i got the motor done i have not had plugs in long enough to wear out. they foul to the point the motor wont run. change plugs and runs like new. i got one year (10k miles) outa the ngk iridiums goin to try some new bosch once i get time to change rearend and trans.
#40
