Fuel injectors
I have 36lbs Accel injectors and I was thinking of replacing. I found some but I dont know if they will work, what is a HIGH IMPEDAMCE AND FOUR HOLES injector. Im really thinking i have some bad ones on the driver side since it floods on 1 side only.
take em out and send or take them to a injector shop to be cleaned and flow tested. that way you will know if any are bad and causing or adding to the issue.
Originally Posted by numskull223
(Post 604405)
and the 4 hole injectors have 4 output holes its supposed to help atomize the fuel better by causing a finer mist |
(Post 604437)
all i know about high impedance injectors is that the resistance of the injector as higher (12ohms) and the low impedance are around 2-3ohms and require a resistor pack to keep from burning out
and the 4 hole injectors have 4 output holes its supposed to help atomize the fuel better by causing a finer mist I wish i knew somewhere to send mine. No place close that i know off. Im just thinking, I have a friend with a set of 24lbs injectors, what if I put those in....wil have to retune it for those. |
i have racetronix 37lb
Originally Posted by NorthernCrew454
(Post 604456)
Youre running them now? Did you have to tune for them? |
(Post 604457)
what city you in
Originally Posted by craby
(Post 604460)
what city you in
man your right, your in a bad place for injector shops. one in georgia About Us - Fuel Injector Connection
