Fuel injectors
#22
Just thinking here...but i bet i can take the injectors off the driver side(flooding side) and put them on the passenger side and see if the flooding changes. If it does thats a sure sign that the injectors are bad....am i thinking right?
#23
My brother told me last night when he rode in the car about a yr before i got it, it had a bad exhaust leak and was flooding back then. Its not skipping or anything.
So with that being said, and only throwing a map low vac code... Would that mess up the O2 sensor on the driver side, the side that floods...
So I pulled it out. Here is is. No crust on the ends and I wiped it clean with a rag. But super black.
#24
that is a fouled 02 sensor. that will cause it to run richer. first had to run rich to foul, once fouled a 02 sensor can read a lean condition when a rich condition is what is real. to clean try heating with torch, i use an acetylene setup. dont know if a propane torch will work. it will burn the black stuff off. dont heat all just the sensor end and not so hot as to melt the wires.
#25
Oh, i found something neat for injectors.
Fuel injector cleaning - YouTube
#26
dont want to use cleaning agents on 02 sensors, also do not want to ground the sensor wire to the housing. high heat is best way to clean, sensor is inside the part with holes so wiping will not help. dont use bosch sensors.
#27
so with that taking care of, can we blame the O2 sensor fory flooding on the 1 side? I ordered a new one....havent got it yet tho.
#29
I didnt ask...ill get a print of everything when i get em back. i was just asking if there was any probs with them before he cleaned them.
#30
Well guys, i feel like an idiot. I was messing with my camaro, trying to see what was causing my flooding on the driver side.......well my headers run into a huge y pipe....and then splits back off in the back, so i guess all my exhaust is coming out the diver side pipe that comes out of the muffler.......that sound right?
