LT1/LT4 Tech 1993-1997
Founders Performance Parts
Old Dec 30, 2011 | 09:32 AM
gagger84's Avatar
Default Founders Performance Parts
Hey guys, I'm thinking about buying some Founders Performance control arms and panhard bar off of Ebay for around $100 and was wondering if any of you have used these parts before. So far I been reading pretty decent reviews and I pretty much use my car as a cruiser with the occasional race, but I wanted to get your opinion. Here is their description:
1982-2002 Camaro or Pontiac Firebird Lower Control Arms
Founders Performance LLC has designed the strongest set of non adjustable lower control arms on the market. These control arms are a direct replacement to your weak, factory stamped rear lower control arms. These control arms are constructed of high strength 1.75" OD steel tubing with CNC machined ends and laser cut main tubes for the ultimate in fit and finish. Founders Performance control arms are supplied with fluted greasable Energy Suspension® polyurethane bushings for a low maintenance control arm kit.
Performance Lower control arms are one of the first parts that should be done on the 3rd or 4th generation F-body. These direct bolt-on replacement arms will minimize wheel hop, improve straight line traction, and improve cornering, while lowering track ETs and helping your launch launch straighter. Control arm kits are shipped complete with powder coated control arms, polyurethane bushings, grease fittings, and zinc-plated steel sleeves.
LCA Features:
1982-2002 Camaro or Pontiac Firebird Panhard Rod
Founders Performance LLC has designed the strongest set of non adjustable panhard rod on the market. This panhard rod is a direct replacement to your weak, factory stamped rear panhard rod. This panhard rod is high strength 1.25" OD steel tubing with CNC machined ends and laser cut main tubes for the ultimate in fit and finish. Founders Performance panhard rods are supplied with greasable Energy Suspension® polyurethane bushings for a low maintenance panhard rod kit.
Performance panhard rod is one of the first parts that should be done on the 3rd or 4th generation F-body. These direct bolt-on replacement parts will minimize wheel hop, improve straight line traction, and improve cornering, while lowering track ETs and helping your launch launch straighter. Panhard rod kits are shipped complete with powder coated rods, polyurethane bushings, grease fittings, and zinc-plated steel sleeves.
Panhard Rod Features:
Please let me know what you think, thank you!
Old Dec 30, 2011 | 10:48 AM
Catmaigne's Avatar
I've had the Founder's Adjustable Panhard on my car for a few thousand miles. It's decent quality and you can't beat the price.
gagger84
Jun 16, 2015 09:15 PM
94camaroV6lover
Apr 18, 2010 07:40 PM
drewwood5
Apr 27, 2008 10:58 PM
z28boss
Mar 17, 2008 10:45 AM
