LT1/LT4 Tech 1993-1997
External Fuel Pump installed in 96 v8 LT1
Old 10-25-2012, 08:31 AM
princesid84's Avatar
Pick one:
1) The stock in tank fuel pump may have died, and the owner didn't want to mess with replacing the original and just installed the external pump because it was easier. Leaving the stock inoperable pump still connected can cause a restriction and make the external pump work harder, shortening it's life.
2) The previous owner purposely installed the external pump to do away with the in tank pump, whatever his reasoning was.
All fuel injected cars since the 1980's have had in-tank fuel pumps. It won't cause the tank to blow up, even in a crash.
Also, does your fuel system still have an operating return line? A return gives relief to the pump motor by returning unmetered fuel to the tank (to form a loop), instead of having the fuel get stonewalled at the end of the line. Generally, a pump without a return in the line will work harder, run hotter, and live a shorter life.
I will change back to intank fuel pump, once(and if) the external fuel pump dies. Will appreciate any suggestion for which (brand/model etc) in-tank fuel pump i should go for, then.
Old 11-03-2012, 02:51 AM
Guys, I am in need of pro advise please.
I ended up posting quesiton in a new theread instead of pasting it here. my query is as under;
https://camaroforums.com/forum/lt1-l...t1-96-a-72283/
Thanks much, for your help.
94Zman
05-30-2013 06:54 PM
jon_uscg2001
08-25-2011 12:23 AM
VettyRestomod-67
06-26-2011 02:46 PM
BlueKitsune
10-05-2007 07:54 PM
johnson3034
05-25-2007 09:35 PM
Quick Reply: External Fuel Pump installed in 96 v8 LT1
