exhaust manifold gasket?
ok so my camaro was sitting for about 3 days, because i was trying to replace the pcv valve and the hose broke so i found out the hard way that it takes a special pre bent hose for the pcv, i order it from the dealer and i got it 3 days later. I install the pcv valve i turn on the hood and i see that in the exhaust manifold from the driver side has spit out like what seems to be vapor. its on the back above the 4 spark plug in driver side. could i have a mest up gasket. Also when i start the car i hear like the exhaust rattles a bit, only when its cold and well sometimes even when its hot. thnax for the help in advance
RE: exhaust manifold gasket?
#4 spark plug is on the passenger side. 4th one back on the driver's side is #7. if it goes pff pff pff pff pff pff pff pff pff pff pff pff pff pff pff pff, then it's likely a manifold gasket. but I don't see how you could have messed it up changing a PCV valve. it was probably screwed up before you got in there, you just got in a position where you noticed it. rattling exhaust? any number of things. heat shield loose, converter shot, muffler shot, hanger loose, collector loose, etc...
ORIGINAL: Gentleman Jack
Ok guys i know its old and stuff , but yesterday i saw when the my driver side exhaust manifold puff out what seems to be water just a little bit from the corner of plug #7, i guess my gasket ismest up, so my question was what damage can be done to my motor? or does it loose power anything? should i change my gasket ASAP? what are the side effects of a mest up gasket?
