Exhaust for 96 Z28
#43
Nothing flows or sounds better than an Xpipe except open headers which I don't recommend. This set up also gives what is known as a "true dual system" meaning each header has its own exhaust pipe.
There is 1 downside to a true dual set up....clearance! you will loose a couple of inches of it. Not really a problem if your car is not dropped.
So go to a decent muffler shop have them do one in stainless steel with 2 bullet mufflers or just order the mufflers yourself off of ebay or whatever they are like $40 each at most. The whole thing should run under $400 installed with mufflers more or less.
oh and you can do a 2 1/2" or 3" set up. Im at work so I cant attach the clip but if you go to my Fquick page and scroll down about mid way is my only video clip with sound and you can see the xpipe set up underneath the car and hear it. It of course does not do justice as it sounds even better in person:
http://www.fquick.com/Zoilus
And IMO .... even though my car is an LS1, LT1's sound even better with this set up!
dbess23
09-17-2007 02:02 AM
javione
02-16-2007 02:27 AM
