LT1/LT4 Tech 1993-1997
EVAP system & P1441
Old Oct 12, 2011 | 03:59 PM
stockpile's Avatar
Default EVAP system & P1441
I was just reading the sticky about testing the EVAP system.
I have DTC P1441, but with no drivability issues and no issues with rough or abnormal idling. I changed the purge valve solenoid, but the DTC returned. That leads me to believe the canister is cracked or bad, which has me worried about charcoal pieces in the lines. What is the best way to check for the presence of charcoal stuck in the lines?
Old Oct 12, 2011 | 08:25 PM
Catmaigne's Avatar
Check to see if the newer solenoid holds vacuum. It probably was gummed up by sucking up charcoal from a canister that's falling apart.
3800camaro
Sep 10, 2011 12:06 PM
Chris666
Jul 15, 2011 05:47 AM
BigCat2010
Dec 15, 2010 01:55 PM
FormulaRS
Aug 19, 2009 02:42 PM
golfballs
Mar 17, 2007 06:56 PM
