LT1/LT4 Tech 1993-1997
Engine temp is high after headers
Old Jun 7, 2010 | 04:59 PM
  #21
Turbolag86's Avatar
Oh ok...so its the fans. Of the two fans, which fan is for the radiator ?
Can I install a switch to where I can turn the fan on whenever I want to ?
Craby, I didn't have to remove the oil cooler.
Old Jun 9, 2010 | 01:28 PM
  #22
Turbolag86's Avatar
Ok, I bled the coolant lines today. There is one by the alternator, and the thermostat. The one by the alternator had a lot of air in it. Once I did that, I took it around the block and now the temp fluctuates between a half a centimeter past halfway and a little below.
Old Jun 9, 2010 | 03:19 PM
  #23
you may have to do it again. it did take a bit to work the air out of mine when i changed the motor. ran on the third mark for a short time. do you have the air damn on and arrr you using anifreeze?
Old Jun 9, 2010 | 09:56 PM
  #24
Turbolag86's Avatar
I'm using a 50/50 coolant...where is the air dam?
When I did bled it the second time coolant just shot out....so I assumed the air bubbles were out....but Idk
Old Jun 9, 2010 | 10:30 PM
  #25
air damn is the plastic skoop under the front bumper. helps to direct air through the radiator.
Old Jun 10, 2010 | 02:30 PM
  #26
torque_is_good's Avatar
Is that why it's there? I could have sworn it was there simply to scrape the ground every time you pull out of a driveway. Dang thing is so bloody low
Dirk88
Aug 20, 2012 06:42 PM
Cammy
Jan 7, 2012 12:30 PM
69flamedss
67-69 V8 Tech
May 23, 2011 10:30 PM
torque_is_good
May 9, 2009 02:10 AM
95camz28
Nov 23, 2007 07:40 AM
