LT1/LT4 Tech 1993-1997
passenger side install LT headers, how high did you jack up your car?
Old May 8, 2009 | 07:28 AM
torque_is_good's Avatar
Default passenger side install LT headers, how high did you jack up your car?
I don't have a service lift. The drivers side was easy once the steering shaft and valve cover were removed, it dropped in from the top. How high up do I need the front end to wiggle that son of a gun into the passenger side? Yes, alternator and starter are out.
It's up on about 18 inch high, (perhaps a bit more) jack stands under the front cross member and no luck. The drive on ramps weren't high enough. Do I need it to be scraping the rear bumper?
Old May 9, 2009 | 02:10 AM
95slvrZ28's Avatar
I had my car up HIGH (enough such that I could comfortably lay under the car and get the header almost vertical under it) and then I had the engine jacked up as high as I could get it without crushing fuel lines etc. for "ease" of installation. There's no way you'll be able to get it high enough on ramps, you need a floor jack and some pretty tall jack-stands.
AmericanMuscle1989
Oct 17, 2013 07:51 PM
Austinscamaro
Jan 15, 2012 09:17 AM
tirocz
82-92 V8 Tech
Mar 25, 2008 05:38 AM
Twizted
Nov 16, 2006 01:48 AM
gotalcoholmanup
Apr 11, 2006 09:24 AM
