LT1/LT4 Tech 1993-1997
Engine Swap vs Rebuild LT1
Old 10-05-2009, 11:37 AM
ussually the cost is about the same as it will cost for a motor that is rebuilt. it of coarse dependant on what needs to be done to the motor. i will have about 5k into mine when done but thats with new block and heads. should be pushin about 400 hp. if your block is good and the cylinders wont need to be bored out, the heads and valves are ok but need vavle job then u will be looking at about 2k for everything. if u want mo power its about 2k to get elliotts to do the heads intake and get a cam of choise. adds some good hp. add five hundred for 1.6 comp cam rockers and a few choise items and u got a hot car. so to build for hp somewhere in the area of 3.5k using your block and heads.
  #32
Old 10-05-2009, 12:25 PM
z28rob18's Avatar
idk wat a rebuild back to stock consists of but i know for my 385 the bottom end cost me $4500 but if your using stock crank stock rods and some different pistons other then diamond pistons you should be able to knock off $1500-2k and lik said above if you want more power you should do heads and cam while your at it. or cam only and spray it
  #33
Old 10-05-2009, 02:57 PM
machine1999z28's Avatar
Just a something to keep in mind, there is gonna be unexpected cost. So always estimate high. When ever I start a rebuild I always add in a grand over total estimated cost just to be on the safe side. Nothing sucks more than to start a big project and come up $500 short.
  #34
Old 10-05-2009, 02:59 PM
If you plan to use spray it's best to go with low compression forged pistons. And as always forged anything=$$$$$$
  #35
Old 10-05-2009, 07:36 PM
z28rob18's Avatar
you don't need low compression but yeah id go forged. although if its a small 100 shot you dont need forged. but with nitrous everyone always wants more
  #36
Old 10-06-2009, 08:20 AM
whammer3024's Avatar
ROTM Winner
i'll be going with forged flat top diamonds in my build and plan to throw some nitrous at it
  #37
Old 10-21-2009, 07:40 PM
motolocopat's Avatar
I'd do two phases... one this winter and then final next...
Get all of the easy bolt on stuff and suspension/wheels all out of the way and then next year do the bottom end
  #38
Old 10-22-2009, 02:32 PM
sm515's Avatar
hey gager....complete gasket set top to bottom, rings, rod/main/cam bearings clean passages and new frost plugs was 800$ at the nearest speed shop. plus labor if ur not doing it yourself, plus anything else you will need: plugs, wires, dist, w.pump ect ect... above are just the basics. good luck.
  #39
Old 10-24-2009, 01:27 PM
gagger84's Avatar
Thank you for your help. I was thinking the price range would be something from $750 - $1500 depending what I wanna get done so that definitely helps clearly some things up for me.
  #40
Old 05-16-2010, 04:10 PM
93 z28 lt-1's Avatar
im rebuilding ma lt-1 an was wondering if i bored 60 over.. it wud still b ok to use as a daily driver? an if any 1 is intrested i have a 350 rebuilt crate engine...thanks.
zachyzee
05-22-2011 02:04 AM
camodragon82
LS Series Tech
08-31-2008 02:21 AM
camodragon82
LS Series Tech
04-09-2008 04:22 PM
jrb78
82-92 V8 Tech
11
12-16-2007 07:05 PM
diamond
04-09-2007 02:14 PM
Quick Reply: Engine Swap vs Rebuild LT1
