EGR System Removal on a 1996 z28
I know someone on ls1lt1 performance has a write up on a 93 z28 but I was wondering if anyone has a writeup on the removal of the egr system on a 96 z28 there are some differences I know that... or if anyone has done and can tell me where to start and how many block off plates I need and what not
im just needing a diagram of the components for the location and stuff.... would I need the block off plates or can I just take the hose off and plug it up for now basically make the egr as a "dummy"
Theoretically you don't need the block off plates, although they make a cleaner solution. Why are you removing the EGR? You're not going to get any power increase from it since it's completely closed at WOT.
I also have a 96 LT1 that I'm putting into a 2nd gen F-body. Of course I want to delete all the emissions stuff and clean up the intake. In the pic, do I need the items I'm pointing at? If I don't, what do I do with the vacuum lines and harness wires? I have already had the PCM programmed to delete the egr and emissions and I don't want any unused plugs or unnecessary crap on the motor...any help would be appreciated
***EDIT** Those would be for the EGR and EVAP. They are now gone along with all wiring and vacuum lines associated with them.
