LT1/LT4 Tech 1993-1997
cuts out only under full throttle
Old Oct 20, 2010 | 03:49 PM
4thknd95z28lt1's Avatar
U fixed it yet, I once had ign switch go out on my colum under the dash replaced it. I then started doing same later stumbling full throttle eventually started to die at full throttle then would restart fine. I replaced switch but noticed the wiring harness plug was burned replaced both this time havent had problem since, back up to performance.
Old Oct 21, 2010 | 11:27 AM
torque_is_good's Avatar
nope
I just got an ALDL cable and ran datalogger. It looks like when you hammer the throttle from idle there is 0 fuel. But, as I said, you can be at 1500 rpms and then slam the throttle and it runs fine
fuel press reg- maybe
fuel pump- doubtful
I'm going to send the capture to Solomon, get his take on it and have him rework the AFR anyway because she's running rich
Old Oct 21, 2010 | 11:31 AM
almost like the computer thinks the car is not running and goes into flood mod and cuts fuel injectors off.
Old Oct 21, 2010 | 03:52 PM
my hunch tells me that there is a nut between the steering wheel and seat that is causing the problem :-)
Old Oct 21, 2010 | 04:07 PM
SloBalt's Avatar
NOOB
January 2012 ROTM
Technical User
Loose nuts behind the wheel of a car is a fast growing problem that is affecting the World by causing high traffic congestion and accidents....
emptysmile005
Feb 28, 2011 10:50 AM
01_VENM
Nov 1, 2010 04:20 AM
Chappie99
Oct 14, 2008 09:53 AM
microkid
Feb 2, 2007 06:45 PM
