LT1/LT4 Tech 1993-1997
crank hub problems
Old May 1, 2010 | 07:35 AM
torque_is_good's Avatar
Aluminum? My LT1 hub is cast iron.
sure is, and don't drop it on your foot if you're wearing flip flops
Old May 2, 2010 | 11:52 PM
r6rider's Avatar
SUCCESS!!!! the boiling method helped. i believe its flush but hard to tell, it wont push on anymore so that should be a pretty good sign. thanks for your help. motors almost complete so ill be sure to share some pics
Old May 3, 2010 | 01:21 AM
i put the socket on the nut and tapped it with a hammer. not hard. then if i got it to move a little more i did it again. took like four times to were it stopped. then i torqued it. i checked it again after running about 50 miles and it was lose so i re torqued it and its been tight sense.
Old May 3, 2010 | 09:48 PM
r6rider's Avatar
ok so i should prob see if i can get it to go a little more. its pretty close to the distributer. ill be sure to double check it
Old May 3, 2010 | 10:30 PM
if u think its bottomed out torque to 75 ft pounds.
Old May 3, 2010 | 11:32 PM
r6rider's Avatar
right on will do. thanks
Mikey.
Jan 12, 2013 08:38 PM
9t4Z28
Apr 15, 2009 08:26 PM
Rfalker1
Dec 25, 2008 08:18 PM
gotalcoholmanup
May 16, 2007 12:59 PM
bobbeam327
Feb 12, 2006 10:29 PM
