LT1/LT4 Tech 1993-1997
Comp Cam Question
Old Feb 4, 2007 | 06:06 PM
z28west's Avatar
Default Comp Cam Question
In summit racing magazine, I came across this cam, and was curious about it. This is a Cam from comp cams, and I was wondering, what this cam was designed for. Is it Low end torque? High end, mid range? How do you tell? Any information about it would be appreciated. Will it have a rough idle? That would be a bonus.
RPMDur@ .050"Lift
1500-5500 220/230 .510/.510
Old Feb 4, 2007 | 11:53 PM
Default RE: Comp Cam Question
If you look at the RPM range it tells you that this cam peaks at bout the same RPM as the stock cam, but should make more power through the range. You really should talk to Comp cams and pick their brains.
Old Feb 5, 2007 | 11:24 PM
z28west's Avatar
Ok, thanks.
JusaV6
Feb 18, 2012 07:33 PM
CHEVYSLAVE
Feb 17, 2011 02:11 PM
skinut
Dec 23, 2010 03:09 PM
mab6680
Oct 1, 2010 12:30 PM
