LT1/LT4 Tech 1993-1997
Car wont start
Old Aug 6, 2010 | 03:30 PM
  #21
xXChipXx's Avatar
Originally Posted by torque_is_good
welcome to strangeness
I've seen coil wires that only fail once it gets hot under the hood
I've had a miss that was random and it was a spark plug that had a small crack and the failure was inconsistent.
On the LT1, I've had the opti harness cause me grief, also an intermittant connection on the temp sensor (the one on the waterpump)
Since most of us haven't owned thse cars from the inception, you really have no clue as to past maintenance. So, as time moves on, you really need to repair/replace wiring and hoses and check your grounds.
You had troubles with your coil wire getting hot and not working? Now that I think about it, when we changed my plug wires, I think we forgot to change the coil wire. It does seem like it gets hot and wont start, but if we let it cool down it runs fine.
Old Aug 7, 2010 | 12:53 AM
  #22
xXChipXx's Avatar
I also pulled my air filter off today. I have a stock intake but it must be a factory performance intake because I dont have a square filter. Actually, my filter itself is K&n. I pulled it off and it was literally caked with dirt. Cleaned it with K&N's cleaning kit. My car runs so much better now.
Old Aug 7, 2010 | 01:26 AM
  #23
lol kool. so is it fixed?
Old Aug 7, 2010 | 07:28 PM
  #24
xXChipXx's Avatar
I replaced the coil wire and cleaned my air filter. When she runs, she runs better, but still wont start when it gets hot. I used component freeze to cool off my opti and it started. So which opti should I get.
Old Aug 7, 2010 | 08:12 PM
  #25
gm performace or msd. ive had both and have heard more issues from the msd but have not had problems with either that i have had. gm performance i had on my first camaro lasted about 90k miles and was still goin when i sold the car.
Old Aug 7, 2010 | 10:04 PM
  #26
xXChipXx's Avatar
So far ive got everything in front of the water pump off. Got all the bolts out of the water pump but it still wont budge.
Old Aug 7, 2010 | 10:28 PM
  #27
there are six bolts on the water pump. it will take a little to get it to move that first bit.
Old Aug 7, 2010 | 10:30 PM
  #28
xXChipXx's Avatar
That explains why it wont move. I got the for that are straight from eachother from top to bottom.
Old Aug 7, 2010 | 10:51 PM
  #29
there one on each side that are tucked back where you cant see them, there about half way between the ones you can see and off the side. .
Old Aug 8, 2010 | 11:08 PM
  #30
xXChipXx's Avatar
Which seal/gaskets should I check or change?
