LT1/LT4 Tech 1993-1997
Car wont start
Old Aug 2, 2010 | 09:42 PM
xXChipXx's Avatar
Default Car wont start
So i went to move my car tonight and she started bu then began running rougher and rougher and finally died. It happened a couple times before but usually a few more tries and it starts right up. It kinda acts like its flooding. I havent changed the infamous opti yet. Could that be it. She usually runs almost perfect but every once in a while this happens.
Old Aug 2, 2010 | 09:54 PM
did you get a ses light? whens the last time it had new plugs and fuel filter? check fuel pressure, test evap sytem, and yes it could be the opti.
Size:  46.1 KBName:  P7300002_1.jpg
from 93 book yours may be a little different, the test should be the same.
Size:  57.8 KBName:  P6030002_1-1.jpg
Size:  49.5 KBName:  P3170041_1.jpg
Old Aug 2, 2010 | 10:34 PM
xXChipXx's Avatar
I just bought it a week ago so it I dont know, but honestly I think the plugs have never been changed. It still hasnt given me a check engine light. I scanned it with an OBD2 but the scanner kept saying "scan failed".
Old Aug 2, 2010 | 10:39 PM
yah 95 is a obd2 plugin and obd1 computer. you will need a scanner that will work on your yr. or you can make a obd1 scanner work with jumper wires. http://shbox.com/1/xraycable.jpg
Old Aug 2, 2010 | 10:43 PM
pull off the vacumm hose for the fuel pressure regulator and see if it has gas in it. if so fpr is toast.
Old Aug 2, 2010 | 10:46 PM
xXChipXx's Avatar
where is that? would that cause my car to work most of the time and the every once in a while not?
Old Aug 2, 2010 | 11:16 PM
xXChipXx's Avatar
I went out and she started right up, doesnt run rough at all.
Old Aug 3, 2010 | 12:39 AM
xXChipXx's Avatar
And my SES light has never come on.
Old Aug 5, 2010 | 03:51 PM
xXChipXx's Avatar
It almost seems like my car only does this when it sits and gets hot. Took it out today and it ran fine, I dont think it missed at all.
Old Aug 5, 2010 | 06:15 PM
test your evap system
