LT1/LT4 Tech 1993-1997
camaro running rough during idle
Old Mar 11, 2007 | 05:25 PM
mtm's Avatar
mtm
Default camaro running rough during idle
Ok I started a thread a few weeks ago about how my camaro had a miss during idle. Well I'm not sure where that thread is now because I just joined and I'm not familar with this site. Anyway, I have been looking around at some LT1 schematics and I noticed it looks like I have a hose in the wrong place. Ok on the right side of the intake (facing the front of the motor) there are 4 lines. A big hose going to the brake booster, a small hose going to the EGR Solenoid, a PCV valve and a vacuum hose going to the distributor. Well for some reason instead of having the hose that goes to the distributor, my PCV valve hose just loops around and plugs into where the distributor vacuum hose goes. See the pictures below to better understand what I'm talking about. Could this be the problem why my car is idling rough? Because I don't have the vacuum hose leading to the optispark?
This is how its supposed to look:
this is how mine looks:
Does anyone know when I get the right lines for this, where does the PCV valve connect and where does the optispark vacuum hose connect on the distributor.
Old Mar 11, 2007 | 09:23 PM
camarorz28's Avatar
Default RE: camaro running rough during idle
what year is your car, is your car a 95? My car is a 94 and the picture for the 95 f-body is diferent from the way my car is set up. I guess there was a change in the year. But if your car is a 94 whichI wouldguess it isyour pcv valve hose is connected to the right place.I would not know about the vaccum hose to the optispark
Old Mar 11, 2007 | 09:35 PM
mtm's Avatar
mtm
mine is a 93 Z28
Old Mar 11, 2007 | 10:51 PM
The 94s do not have hoses to the distributor. You may want to do the plugs & wires thing, if you havent changed them already. Also check for trouble codes.
Old Mar 12, 2007 | 04:05 AM
sellc's Avatar
The PCV hose should route under to the throttle body. Seems they have the PCV valve routed to a diffrent area. I wonder what they have on the barb at the throttle body to plug it off.
A 94 shouldbe a non-venteddistributor unless its been upgraded. Even so I would be curious to see what they got running to the barb under the t-body.
In this photo you can see the barb on the bottom left drivers side that should go to your PCV valve.
[IMG]local://upfiles/4555/85B682B9EAFD43D484237DC08CC285AE.jpg[/IMG]
Old Mar 14, 2007 | 06:11 PM
carguylt1's Avatar
There should be another vacuum line that goes to the air injection (I think that's what it's called.) on the same side. That's the way it is on my 95z.
Old Mar 14, 2007 | 10:54 PM
Go to your local Chevy dealer and order a VECI label for your car, about $5. It shouldshow a diagram coverng all the hoses involved with emission control.
RedSled99
Sep 28, 2013 11:37 PM
Chaotic94
Jul 10, 2013 10:44 AM
csmiddy
67-69 V8 Tech
Dec 9, 2012 10:12 PM
keaboi
Oct 6, 2011 10:25 PM
libertyforall1776
Aug 22, 2010 11:50 AM
