LT1/LT4 Tech 1993-1997
cam or tuning problems
Old Sep 17, 2009 | 04:18 PM
Bacamaross's Avatar
Default cam or tuning problems
i have a 93 camaro i just put a a set of 202 heads and a comp 280XFI HR13 Cam. i had it dyno'd and the computer modded by a performance shop. the car bucks spitts and sputters till about 2300 rpm exc for when its cold. the guy said its from the size of the cam and he cant do anything about it. it also blows black smoke at an idol.
Does anyone have the same size cam and have this problem or is there any thing i can do about this?
280XFI HR13
280
288
230
236
.576
.570
cam specs
Old Sep 17, 2009 | 05:00 PM
whammer3024's Avatar
ROTM Winner
auto or manual? what do you mean by 202 heads?
Old Sep 18, 2009 | 04:51 PM
Bacamaross's Avatar
manual - patriot heads 202 intake 160exh.
Old Sep 18, 2009 | 06:59 PM
Apparently your tuner was not up to the task. Black smoke at idle and rough running at low RPM is ususally caused by a too rich A/F mixture which can foul plugs and cause misfires and make things worse. You may want to call PCM for less and get the PCM tuned.
rdominy
Jul 18, 2021 08:52 PM
fastZ
Feb 27, 2010 07:15 AM
rwing7486
Jul 30, 2009 11:35 AM
Camaro_Boi69
Feb 7, 2009 12:56 PM
rayski
82-92 V8 Tech
Jul 2, 2007 07:27 PM
