LT1/LT4 Tech 1993-1997
burnt distributor please help !
Old Apr 26, 2006 | 08:35 PM
randscr's Avatar
Default burnt distributor please help !
i have a 1997 z28 lt1 camaro. twice in a one month period i had to replace the distributor because the engine wont start and the distributor had a burnt mark on the back. its close to the edge and also right next to it the is a vacum line connected to the cap . the port were the vacume line connected to it also looked like it fried also. please help me anyone !!!!!!! thsnk you for your responces.
Old Apr 26, 2006 | 09:58 PM
shnormo's Avatar
Default RE: burnt distributor please help !
Do you have a stock coil? Does yours still have a rotor? If there is high resistance in the spark plug or the wire, it will cause it to burn. If you haven't changed the rotor and it has one, it will make the distributor cap burn out quicker.
Old Apr 26, 2006 | 10:06 PM
Check your water pump, especially the weep hole, & make sure no liquid is dripping on the Optispark. You get the opti wet and you soon have to replace it. It is good practice to replace the water pump whenever the opti is replaced, as is good practice to replace the entire Optispark, raher than just the cap & rotor. Also, as Norm mentioned, make sure your plug wires and sparkplugs are in good condition, otherwise the spark will find the path to ground that has the least resistance.
Old Apr 27, 2006 | 08:45 PM
94Z28SHAKER's Avatar
In addition to what they said^^^^^^
you said the port where your vacuum line goes keeps getting fryed, i would definately make sure no moisture is trapped in the vent tube, and also make sure nothing gets wet going into your intake elbow, kida sounds like you might have a leak in that tube thats shorting out the opti. hope that helps.
Old Apr 28, 2006 | 02:28 AM
Very good point 94Z28SHAKER.
Rob79
Mar 16, 2010 10:38 AM
down33
Jun 9, 2009 10:13 PM
Dills86irocz
Aug 3, 2008 08:26 PM
BleuBird
Aug 11, 2007 12:30 PM
McNasty
VS
Mar 19, 2006 03:18 PM
