Brights are stuck on!!
![Icon Doh](https://camaroforums.com/forum/images/smilies/icon_doh.gif)
![Confused](https://camaroforums.com/forum/images/smilies/confused.gif)
what yr car? there should be a shaft that goes down the steering column to the dimmer switch. it may have come unhooked or bent. also dimmer switch could be bad or broken.
What craby said! I just fixed one on my daughters car. It is a 98. I had to drop the steering column down in order to adjust the switch. I am not a contortionist and could not get in the right position to loosen the 2 little screws that hold it to the steering column without lowering the column, then after laying on my head for 15 minutes, I needed that little "I've fallen and can't get up" device to get out of the floorboard! LOL.
