stuck
Old Nov 12, 2010 | 11:38 AM
Lj2069's Avatar
Default stuck
i just replaced the clutch in my car and put in a zoom performance clutch. now that is fixed i need to replace the linkage because my car has trouble finding reverse and once it finds it it sometimes gets stuck in it when i put the car back into nuetral or another gear. anyone have any links to what i need for a good price? and some tips for putting it in?
highly appreciate your guys help.
Old Nov 12, 2010 | 06:49 PM
have you tried to adjust it? or is it pretty mushy.
Old Nov 12, 2010 | 08:02 PM
Lj2069's Avatar
yeah we tried to adjust it. it was really loose so we tightened it up but not its back to the way it was. so im just gonna replace it before it gets any worse. i barely have reverse as it is now so i dont want the other gears to get ****ed up. do u know any links to what i need? cause i cant find any.
Old Nov 12, 2010 | 08:39 PM
i think this is one that will fit. what trany?
http://www.summitracing.com/parts/HU...RO&prefilter=1
Old Nov 12, 2010 | 09:59 PM
Is it the shifter itself that's sloppy, or the linkage rods? Are the rod bushings worn out? If the bushings are shot, it will make the linkage sloppy and alter the throw.
Old Nov 12, 2010 | 10:49 PM
The shifter is my vote as well. I had an ITM in my 76 Nova, hung up like a turd. Try and fix the bushings as stated and maybe try to shift it lightly. I can't really decribe what I mean other than as you go from gear to gear, find neutral first then go to the next gear. Mine was so loose I could stir it. Changing gears fast would always cause problems, specially 2-3 and 1-R.
Old Nov 12, 2010 | 11:25 PM
Lj2069's Avatar
the bushings are shot and the rods seem like they are going but idk if new bushings will just make them good again. i dont have trouble going through the gears 1-4 its just reverse that is screwing me at the moment. but if im replacing the bushings i rather just put in new rods as well.
Old Nov 12, 2010 | 11:39 PM
The bushings are a wear item. If the rods are worn down too, you'll be able to see a ridge where the bushings were riding and sawing at the end. If the rod ends aren't worn down, buying new ones would be money wasted.
Old Nov 12, 2010 | 11:51 PM
Lj2069's Avatar
im not sure i guess i'll just buy the bushings first and if i go to put them in and see that the rods are worn down then i'll replace them. do you know a website that has the bushings? i cant find them. idk if im looking in the wrong places or what.
Old Nov 13, 2010 | 01:25 AM
