LT1/LT4 Tech 1993-1997
Brake problems on LT-1
Old Apr 3, 2009 | 10:04 AM
Ivan Evdokimov's Avatar
Default Brake problems on LT-1
Hi guys! My name is Ivan, I am from Moscow, Russia, and this is my first post here.
I have a '93 LT-1 Firebird (w/ABS but without traction control) and experience some brake problems:
1. I need to press brake pedal almost to the floor to brake.
2. Brake pedal sometimes feels floppy.
There are no leaks in the system. I also tried to bleed the system according to manual. Nothing changed.
I think the cause of the problem is master cylinder.
Questions:
1. Could it be something else? (e.g. ABS module)
2. Could you recommend better-than-OEM solution for master cylinder upgrade?
Thank you.
Old Apr 3, 2009 | 10:08 AM
z28rob18's Avatar
from the discription it sounds lik there's air in the lines but u said you bled them. i replaced mine with a stock replacement idk if there's any other way to go.
Old Apr 3, 2009 | 03:10 PM
Y2K's Avatar
Y2K
I think you're correct.
Old Apr 4, 2009 | 12:53 AM
if it pulsates or goes on and off by itself while you are putting the brakes on then i think it would be in the abs. my truck did that and it was the abs. went all the way to the floor and then worked. it pulsated as it was going down. after the first time then it went to the floor before working every time but didnt pulsate every time. you all having a cold spring there to.
Old Apr 5, 2009 | 03:35 PM
Guys, thanks for the answers.
The symptoms are quite similar to mine. Will check ABS first.
Yeah, spring is not the warmest one. But anyway I am sure you do not have snow in DC right now. While we did have in Moscow just yesterday
Old Apr 5, 2009 | 11:27 PM
greenarrow's Avatar
September 2009 ROTM
is there a ABS inop light on? If so then it more than likely is a ABS problem.
Old Apr 6, 2009 | 01:36 PM
Yeah, the light is on, but I thought it was another problem.
Old Apr 7, 2009 | 05:38 PM
383Stro's Avatar
This link will show u the route to take from where u are. Have fun with that ABS block. Sounds like you have air in it. Hard to get out....gl. I would go this route first..no need to but a master cylinder or brake booster for no reason. Stock is plenty, dont waste your money there, when there are so much better areas to spend it on your car.:-D
There should be 2 bleeder screws on the abs module, bleed the back one first, then the front one. After that, bleed the system as you normally would working from the caliper farthest away from the master cylinder to the closest. Then bleed the abs module again starting with the front bleeder, then the back bleeder. Then you can either use a scanner to cycle the abs valves to free any air bubbles, or if you dont have a scanner you can turn the key on for around 10 seconds or so then turn it off and repeat that around 5 times. Turning the key on and off like that supposedly cycles the abs. Then you are supposed to re-bleed the whole system. Repeat this process until the abs light no longer turns on. Thats what the actual gm repair manuals say to do anyway. It's been a while since I've done this and I don't have the manual in front of me so I might be slightly off. Hope this helps.
http://www.ls1tech.com/forums/suspen...kes-w-abs.html
Old Apr 8, 2009 | 12:55 PM
383Stro, thank you VERY much!
Mikey.
Jul 19, 2011 10:07 PM
Conundrum
Jan 12, 2007 03:24 PM
scotty22s
Jan 9, 2006 02:39 AM
highpowerd2003
Dec 21, 2005 11:02 PM
highpowerd2003
Dec 2, 2005 07:15 PM
