brake problems
Old Dec 1, 2005 | 08:16 PM
highpowerd2003's Avatar
Default brake problems
no brakes, air is bubbling in master cylinder, no leaks. whats going on.
Old Dec 1, 2005 | 08:35 PM
TimmyTheWop89's Avatar
Default RE: brake problems
you have air in the brake lines,need to bleed them. buy a tub of brake fluid. this takes 2 people. pump the brakes quickly, then push it down all the way, have someone pour the fluid in slowly, as you slowly releases the brake. repeat over and over again, about 2 to 4 times. this should solve the problem, but if by any chance it desnt, you may have maybe a clog in the brake line, or a brake caliper may be froze. i doubt its clogged as there would be no bubbles appearing. hope ive helped
Old Dec 2, 2005 | 07:15 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
what also i find helps more is the power bleeder that hooks up to an air line and actually sucks the fluid through the bleeder screw. it takes out some seriously tough air bubbles in the lines
Mikey.
Jul 19, 2011 10:07 PM
Ivan Evdokimov
Apr 8, 2009 12:55 PM
Conundrum
Jan 12, 2007 03:24 PM
scotty22s
Jan 9, 2006 02:39 AM
highpowerd2003
Dec 21, 2005 11:02 PM
