bolt on mods
i think tht you should do full exhaust headers, intake, underdrive pullys and if you have a little extra cash left over buy a cam because all tht flow isnt going to do much unless you put some more lift on those valves and you have to do springs too.
Under drive pullies are pretty close to a useless mod on a 4th gen. The only thing the belt drives is your water pump, alternator and your A/C when you have it on. You're better off getting an electric water pump than the under drive pullies, that way your A/C works and you don't risk running into issues with your battery not charging as it should because your alternator isn't spinning fast enough.
im 18 too can i have a prize?like everybody said already exhaust is one of the first mods to do.. but if your looking for cheap power nitrous is #1 for some real power for not much money. just dont over do it on a stock engine and get a wet system if you choose too.
ORIGINAL: 95slvrZ28
remember , an engine is a big air pump. the more air you can get in and out , the better it will preform. start with a nice cold air kit , some decent headers and full exhaust , your $1500 is pretty much gone then , but you will feel a noticeable gain in power and get better fuel mileage to boot.
ORIGINAL: Spartan66
I read in Camaro Performers that you can use a smaller underdriven pulley to create more boost... but that was installed with a Vortec S-Trim charger.
#20
thanks for all you help. i think i am going to buy a $300 leaf blower and hook it up to my intake and boom right there like 8lbs of boost. ya i am kidding about all the but still thanks for all your help. if i where to do all boltons intake and exhaust eletric water pump around how much hp can somone get with just external work. i am 18 too yaaaaaa lol.
