LT1/LT4 Tech 1993-1997
Ajust rockers
Old Aug 24, 2010 | 03:48 PM
Originally Posted by critt86
(adjust oops)What is the best way to adjust them? I have too much noise.
Unless you just had the engine apart and are putting it back together, your "too much noise" is most likely to be from a bad lifter(s). Hydraulic lifter engines don't generally just "fall out of adjustment".
Old Aug 24, 2010 | 05:46 PM
critt86's Avatar
i just had the motor put together couple of months ago.
Old Aug 24, 2010 | 08:34 PM
osduck5's Avatar
I am actually going to be doing this tomorrow, work permitting. I replaced the head gaskets today and put the heads on. I think I am going to use the up/down method for starters and then fine tune it, if it starts with the engine running. First time I have adjusted rockers on LT1.
Old Aug 24, 2010 | 09:12 PM
i had to readjust miine after a couple hundred miles. seems one was sticking or something to began with and has been working fine now after adjusting.
VALHAR
Oct 9, 2014 12:19 PM
bryans3.4 95
Nov 25, 2008 11:56 PM
xPBxWrEckeD
82-92 V8 Tech
Nov 20, 2007 12:02 AM
DKap22
Mar 14, 2007 07:52 PM
camarokid1968ss
Apr 23, 2006 12:34 PM
