LT1/LT4 Tech 1993-1997
Air Pump
Old Nov 19, 2007 | 03:56 PM
Turbozombie's Avatar
Default Air Pump
Where is the electrical connector to disconnect the air pump on a '94 Z28?
And will this cause the check engine light to come on?
Old Nov 19, 2007 | 05:46 PM
Default RE: Air Pump
The connector is right on the AIR pump. Yes, the check engine lite will go on. Keep in mind that the AIR pump works only for a few minutes, just enough to light up the cat converter. Removing or disconnecting the pump will not add any power, but allow the cat to get fouled sooner.
Old Nov 20, 2007 | 11:29 AM
I have no cat on the car, had it removed when the exhaust was done. How long is the air pump running for, especially on cold mornings?
Old Nov 20, 2007 | 12:08 PM
CRanMaro99's Avatar
April 2008 ROTM
I heard it weighs about 20 pounds or so. That would be the only real reason to remove it (if you have no cats/emissions) aka weight reduction.
Old Nov 20, 2007 | 01:44 PM
Runs for 3 to 4 mins, and weighs no where near 20 lb.
Old Nov 26, 2007 | 12:49 PM
camaro_burns_all's Avatar
VIP member
why exactly do you need to remove it?
Old Nov 26, 2007 | 01:36 PM
SpecterGT260's Avatar
Ninja Administrator
you dont need to. it doesnt really do anything for you. I removed mine, it was on the driver side in a little compartment in front of the tire. id assume camaro's have it in the same place. thing weighed maybe a couple pounds.
94z28chevy
Aug 17, 2012 07:05 AM
shoff24
Dec 28, 2010 04:12 PM
oliverjohn
Jun 4, 2009 10:28 PM
twiz
82-92 V8 Tech
Jul 21, 2007 12:27 AM
jvande7471
Mar 1, 2006 08:48 PM
