LT1/LT4 Tech 1993-1997
Air in leakage
Old 07-17-2012, 10:03 AM
cclovern's Avatar
Default Progress so far
All
So far I have yet to find the problem , I have changed the intake gaskets and sealed the oil leak. I cleaned the injectors and changed the fuel filter , fuel pressure with key on is 41 psi , engine running its about 14 psi.
I checked each injector with a noid light and it is blinking. I went over the exhaust down to the cat no leaks.
I went through the wire harness from the ECM to each sensor and found no problems. I went over the grounds for the ECM and thought I had found the problem but no dice. I ran the engine after working on the grounds and it ran much better had a slight miss, turned it off to trace down the miss and when restarting it ruturned to the same problem.
I disconnected the ECM and checked for a performance chip none was installed. I closed it back up and plugged it in the engine would not start. let it set overnight to cool my temper and have a few cold ones and think over the problem. Tried it the next day it started and ran rich again.
At this point I am relegated to two options the Optispark or ECM. The Opti was replaced at a local garage and I spoke with the mechanic that did the install. He seemed confident in the repair. The engine would idle and run after the ground work I did earlier so the Opti will be the last item I will address in my mind.
In a previous post someone had mentioned the air filter it is new and the intake is clean.
Any ideas ?
Old 07-17-2012, 12:14 PM
fuel pressure is 14 at idle??? id say you have a fuel problem. pump or pressure regulator
Old 07-17-2012, 12:48 PM
14 PSI? Finally fessed up.
Old 07-26-2012, 05:29 AM
cclovern's Avatar
Default Update
Looking into the fuel pressure found the new fuel filter plugged , drained the tank and flushed all lines. It maintains fuel pressure now, cleaned the injectors again and flushed the fuel rail and all lines from the filter forward.
Procured a reman ECM and installed it runs now and will idle , no rich condition. I am changing out the plugs they were fouled , hope the O2 sensors clear up with a drive.
I have purchased the Moates ALDL cable and have the software to read data, next item to find an old laptop. I think the ECM was a large portion of the problem it seems the injectors were firing all the time. Going to send ECM out for repair and get failure cause. I found the alternator was putting out about 15.7 volts and have one enroute.
I picked this up for a project and have learned a lot about newer engines and their control systems.
One note found a video on you tube about injector cleaning, used it the second time and it worked well.
Old 07-26-2012, 04:38 PM
cclovern's Avatar
Default 1st ride
Replaced the alternator today, replaced plugs and she started and idled @900 rpm no smoke, no stalling or other issues thus far. Took a short ride and was smilin the whole time.
The pads and rotors need replaced and the brake lines as well , but it seems to run ok.
Again thanks to all for your advice and technical direction , off to change oil and filter and have a few cold ones to celebrate.
Old 07-27-2012, 08:10 AM
torque_is_good's Avatar
good for you. There actually is value to all of the sensors. You'll now chuckle as well when you hear people say they are going old school.
ROBCAMV6
04-11-2010 05:31 PM
danni97
01-25-2010 07:08 PM
9camaro5
04-17-2009 09:53 AM
bprzybyl
04-20-2007 01:48 AM
85Camarodude
11-01-2005 05:50 PM
Quick Reply: Air in leakage
