LT1/LT4 Tech 1993-1997
AFR heads...
Old Jun 22, 2009 | 06:46 PM
rondavis's Avatar
or you can pull your valve cover off and google the casting number that will tell you if they are stock of if they are the AFR heads
Old Jun 23, 2009 | 01:46 AM
black95z28's Avatar
where would the casting number be?
Old Jun 23, 2009 | 11:27 AM
rondavis's Avatar
the casting number is on either side it is the little number that is read from bottom to top and should be like 4 to 6 numbers there be a set of biger number read right to left it will be just above that number
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
