96 z28 overheating
I am constantly having over heating problems. On the street but on freeway is ok. Can someone explain how to keep the fans on always. I think that is the problem. I have a bra on it but it doesn't restrict the air flow at all.
Welcome, Robert, to the Club.
You might try street driving without the bra and compare results.
Ensure the spoilers and other devices are in good physical condition and in place.
Coolant level where it should be, radiator cap is good and system develops pressure by feeling hoses are taut.
You might have to wire in a toggle/rocker switch for the fan relay(s) as you can then manually control the fan(s) operation.
Fans should come on when MAX A/C is selected.
