LT1/LT4 Tech 1993-1997
95 z28 6 speed overheating
Old Mar 11, 2008 | 10:59 PM
noz's Avatar
noz
Default 95 z28 6 speed overheating
my z28 is overheating when im crusing the temp. niddle goes all the way up then when i accelerate it goes tohalf or normal then when i stop is goes to270if anyone had this problem before please let me kno.
Old Mar 11, 2008 | 11:15 PM
BluBeaSSt's Avatar
Default RE: 95 z28 6 speed overheating
Im gonna guess you have a air pocket, have you burbed the cooling system?
Old Mar 12, 2008 | 12:08 AM
noz's Avatar
noz
what you mean burbed the cooling system?
Old Mar 12, 2008 | 10:52 AM
DrRuckus13's Avatar
Doesyour temperature correct itself when the A/C is on?If so, thenyour movingto slowand not enough aircan gettothe radiator.then try a flush and see if that fixes it.
I have to run the A/Calot in traffic because my Z gets dangerously hot FAST!
Old Mar 12, 2008 | 12:29 PM
libertyforall1776's Avatar
What year is yours? Install the Prestone Flush Kit, and flush it yourself -- cheap at Wal Mart...
Next might want to replace the thermostat if your car is kinda old -- inexpensive, and they do fail...
Next ensure your water pump is not weeping -- if so, it is failing.
Old Mar 12, 2008 | 12:35 PM
Saint_Ali's Avatar
try bleeding the system, there could be air like mentioned before
also could be your thermostat, but the way you describe it, it sounds like there is air in the system
DiElSleL
Mar 8, 2012 01:23 PM
DiElSleL
Mar 6, 2012 10:54 PM
rext
67-69 V8 Tech
Sep 23, 2011 11:49 AM
