LT1/LT4 Tech 1993-1997
96 z28 lost reverse
Old Mar 9, 2012 | 08:40 AM
oreos96z28's Avatar
Unhappy 96 z28 lost reverse
hi nmaes heath new to the site thanks for having me....anyways me and my wife got a 96 z28 and i sudenly lost reverse. Like when i shift from park one down is neutral then 2 down is drive im wondering if the linkage is off or sumthin anyone have a solution
Old Mar 9, 2012 | 08:54 AM
Sounds like the linkage is off or sumthin. Since one down from park should be reverse, something is outta whack. Need to get under the car and look at what the linkage arm on the trans is doing while a helper runs it through the gears. The arm could have come loose, or the cable mount could have come loose, etc.
Old Mar 9, 2012 | 07:34 PM
90Blazer's Avatar
Sounds like the sun gear carrier to me. The factory one is weak, had mine go out in my truck same symptoms. How many miles on it?
Old Mar 9, 2012 | 08:45 PM
torque_is_good's Avatar
I dunno 69
think about it. I might agree with you if for example he could not get into low. As you pull the lever back from park the next stop is rev. He says he pulls back and gets D so the cable is still attached. The question is how much travel is this "one down" ?
sounds like a sprag to me
Old Mar 9, 2012 | 11:43 PM
lol....oh man. I swear I saw that he was hitting reverse further down the gate. Ok, who took the words out? Yep, I don't see it as a linkage issue either.
I'm gonna go rub my eyes some more now! heh, heh
Old Mar 10, 2012 | 10:53 AM
It is alaways sumthin, or it could be sumthin else. lol
Old Mar 10, 2012 | 11:22 AM
At least you narrowed it down to being one of two things. lol
"alaways"? Yoo miss speled sumthin their! Talk about calling the kettle a pothead (or sumthin like that)!
Old Mar 10, 2012 | 08:09 PM
if this were a truck I'd tell you to slide underneath and move the lever on the tranny tio reverse and see if it actually goes into revers.
But, since it's a camaro you'll need to get her up on stands (all wheels in the air) and slide under and put it in R and see if it turns.
stupid question but did you check your fluid level?
skinut
Apr 11, 2015 01:43 PM
chevycrazy32
Mar 26, 2011 09:27 PM
boylemyster
Sep 5, 2010 12:14 PM
dorkpunch
Jun 29, 2008 08:54 PM
73 T Top
Aug 10, 2007 12:20 AM
