LT1/LT4 Tech 1993-1997
94z Trunk problem
Old Sep 6, 2006 | 01:40 AM
camarorz28's Avatar
Default 94z Trunk problem
Is there any sensor or a fuse for the button that open the trunk inside the glove box, when I press the button a sound comes out of under glove box but the trunk would not open. I also change the trunk lock but it would not open
Old Sep 7, 2006 | 03:17 AM
95slvrZ28's Avatar
Default RE: 94z Trunk problem
What sort of sound does it make? If it is simply a click, I'd say that your button or some other electric component is shot, but if it make a "jeekoo" sound(yes, really descriptive, I know.../sarcasm), that means the electronic latch is unlatching. Often times when my I open my rear hatch I have to grab the hatch fron underneath the "Camaro" lettering, pull down slightly, then lift.
Another thing I just thought of, does your remote on your keys work to unlatch the trunk, or is it only the dash button?
Old Sep 9, 2006 | 04:08 AM
camarorz28's Avatar
its only the dash button i dont have a keyless remote. And yeah there is only a clicking noise.
Old Sep 11, 2006 | 01:08 AM
The button operates tha hatch release relay mounted under the right side of the instrument panel. The relay operates the hatch release actuator (motor) at end of cargo area under hatch lock. Press the button & see if you are getting voltage at the black & white wire at the actuator. Make sure the black wire coming from the actuator makes good connection with ground. If both are good try replacing the actuator. Otherwise, check the relay and all connections. Also make sure the hatch is adjusted properly as too much pressure on the lock will prevent the actuator from releasing it.
CZimmer
Jun 3, 2012 01:25 AM
87camarospeed14
Apr 7, 2009 03:52 PM
camaraddict
Jan 23, 2008 07:02 AM
Cpuma2427
Dec 22, 2006 02:10 PM
trailerparktrash2009
Sep 28, 2006 02:44 AM
