LT1/LT4 Tech 1993-1997
94 Z28 staring problem
Old Jun 1, 2013 | 08:22 PM
sbono's Avatar
Default 94 Z28 staring problem
Need help, I have a 94 Z28 M6 that started acting up recently. One day the car is running fine, next thing I know I tried to start the car and it would try to start but die immediatley. Ater several attemps it finally started, the next day i went to start it and all it would do is turn over, not even try to start. So far all i have tried is to check the fuel pressure with a guage and the results were 41psi when the pump is running and when it kicks off it goes down to 38psi but holds steady. Of course i can't test it running because it won't start. Any help would be appreciated. Thanks
Old Jun 1, 2013 | 10:02 PM
check for spark?
Old Jun 1, 2013 | 10:04 PM
look at the link in number 2 here https://camaroforums.com/forum/93-02...rt-here-38462/ see if that helps.
Old Jun 2, 2013 | 05:43 PM
sbono's Avatar
i have spark. Talking with a mechanic he said it could still be the pump, even though the pump has 41psi (which is on the low end of acceptable) it might not have the required volume because of a clogged sock. Has anyone heard of this?
Old Jun 2, 2013 | 08:33 PM
something for your reading pleasure. 4th Gen LT1 F-body Tech Articles
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
siueparent
Oct 19, 2009 08:30 PM
2lucke4u
Sep 1, 2006 09:55 PM
