Security Light, Staring problems!!!!
Old Oct 13, 2009 | 04:55 PM
siueparent's Avatar
Default Security Light, Staring problems!!!!
Ok today the car ran fine and I parked it and it wouldnt starts anymore. The security light stays on always while driving. So now when I start it nothing happens at all no lights come on the dash except the security light, it doesnt bink it just lights up. The bcm is reading the resistor because I bypassed the sterring column and connected it below the steering wheel.
Old Oct 13, 2009 | 05:57 PM
what yr and model? depending on the yr i believe theres a enabler for the ignition under the dash on the door side of the glove box. check your fuses under the hood in the black box on the driver side fenderwell and on the side of the dash by the driver side door. if u have a bcm then its a newer model and u may not have a enabler. if u dont have one get a repair manual, preferably dealer service/shop manual for your yr and model. only way to go.
Old Oct 13, 2009 | 06:04 PM
siueparent's Avatar
Its a 2000. The security light stays on in the acc. also. No other warning lights come on when I try to start the car. The security light just stays on
Old Oct 13, 2009 | 07:47 PM
siueparent's Avatar
No warning lights show on the dash just the security light but the fuel pump comes on
Old Oct 13, 2009 | 09:12 PM
auto's Avatar
clean the key and dry it good, if not try another key, and make sure that little pebble is in the key
Old Oct 14, 2009 | 11:36 AM
GMDCAMARO's Avatar
Your "VATS" chip, on your Key, may be worn and no longer giving the proper resistance to the ignition.
Old Oct 14, 2009 | 11:59 AM
pretty sure he said he bypassed the key with a resistor. and op have u checked the wiring to the bypass and maybe the resistor went bad.
Old Oct 14, 2009 | 01:39 PM
siueparent's Avatar
If the resistor went bad would it cause the dash warning lights to stop falshing? at first when I had the wrong resistor the dash warning lights would flash and the security light would flash for three mins and I could try a new resistor.
Old Oct 14, 2009 | 01:57 PM
javb_vb's Avatar
ooh, on that week that work the light was always on? it is because the resistor its a little diferent from the resistor in the key if u have a multimeter see check for the exactly resistor it needs, well here are the procedures for the diagnosis
File Type: zip
File Type: zip
Old Oct 14, 2009 | 02:55 PM
siueparent's Avatar
I disconnected the battery last night and went to start it today nothing still. I did notice that the dash gauges doesnt move anymore.
