LT1/LT4 Tech 1993-1997
93 Z28 starts then stalls
Old Mar 31, 2010 | 02:20 PM
KENCO's Avatar
Got a hold of a known good coil and a module to test tonight. Also I have an MSD ignition box in the car so I called them and they walked me thru on how to test their box to see if that is the problem. Hopefully I will have the answer tonight as to what the problem is.
Old Mar 31, 2010 | 05:35 PM
KENCO's Avatar
It was the MSD ignition box that was causing the problem. I tried another coil, another module, no luck. I unburied the MSD and played with the wiring and it revealed the problem. I then took the MSD out of the loop and it starts and stays running just fine.
Old Mar 31, 2010 | 07:33 PM
cool got the ride back on the road. good deal.
Old Apr 1, 2010 | 05:05 AM
KENCO's Avatar
Yes, but the stock ignition sucks compared to what I was used to with the MSD. The unit is over $300.00, so I am calling MSD to see how much it would be to repair. Also need to add a blaster coil.
96CamaroLT-1
Dec 11, 2011 06:42 AM
oasr987
82-92 V8 Tech
Oct 4, 2009 02:49 AM
patty1
Mar 11, 2008 07:08 PM
Foskey
Aug 18, 2007 01:00 PM
mongo
Nov 14, 2006 10:38 PM
