3000$ performance build
If you can do the work yourself, get LE2 heads and a cam, headers, a tune, fuel pump, injectors and upgrade to C5 brakes if you have 18" rims, or LS1 rotors if you have the stock wheels. And if you have enough money, beef up the rear end because it WILL detonate...
Good luck and kill Rustanks!!
x01660
x01660
check here http://www.elliottsportworks.com/ for the le2 heads and cam. you will need 1.6 rockers, push rods, lifters, i would suggest that when you order from lloyd let him know what you want, he is very good and will give you an idea of what you will need to go with the heads and cam. then its a matter of finding the best deal.
