LT1/LT4 Tech 1993-1997
1st to 2nd hesitation
Old Mar 27, 2007 | 03:35 PM
toml14's Avatar
Default 1st to 2nd hesitation
Had the 93 Z28 out today and was running it pretty hard out on the back roads. I noticed that under hard acceleration from a dead stop, the car will pull first gear till it hits the rev limiter and will not hit second gear till you let off. The trans shifts perfectly other than that and has no problems grabbing second if not @WOT. I would like to get this fixed as its not going to help this summer at the track. Does it have to do with the kick down cable adjustment? Mods on it include JET performance stage 2 chip, full exhaust with offroad "Y", K&N CAI, and no cat. Car has just under 90k on the odometer, trans fluid flushed and filter changed within the last month. While I'm at it, has anyone installed a PCMforless chip in their lightly modded LT1s?? I would like to swap out the JET and go with one of theirs if they are as good as everyone claims. Thanks for the time!!
Old Mar 27, 2007 | 06:31 PM
Default RE: 1st to 2nd hesitation
Try resetting the TV cable, if that doesn't work see atransmission shop. The car has a 700r4/4L60 transmission that is not computer controlled, so the engine mods should have no effect on shift points.
Old Mar 28, 2007 | 06:01 PM
toml14's Avatar
Thanks for the reply Pete! Any suggestions on how to reset the TV cable? I know on my 82 chevy pickup there is a slide that can be moved back and forth to adjust the pressure. The one on the Camaro looked similar but not the same.I guess I can read the manual too.
Anyone got anything on the PCMforless tune??
[/align]
Old Mar 29, 2007 | 02:34 AM
toml14's Avatar
I pushed in the reset tab and slid the slider all the way back (towards the firewall) untill it stopped, then released the tab and rotated the throttle all the way open. The slider ratcheted out about 1 click and was done. Hope that does the trick. I will test drive tomorrow.
cadmanof50s
Aug 1, 2011 10:42 PM
eighty-eight-iroc
Jun 15, 2010 08:01 PM
ryan88z
Mar 26, 2008 10:51 PM
amnesia206
67-69 V8 Tech
Jan 25, 2008 05:06 PM
renee
Aug 12, 2005 11:13 PM
