what gears does my a4 have?
ok I have a 00'z28 a4. I heard there is a way to check with your vin# to see if you have 2.73 or 3.23 but i'm not sure. my shift pattern goes. 1-2-D-OD-N-R-P
should be a label in the glove box or the center console with your option codes on it. its a three caracters and have letters and numbers. gu2 is a 273 gu3 is a 323 gu4 is a 342
on my door panel there were many three digit codes one of them said gu2 so i guess that equates to a 2.73
GU1 : AXLE REAR, 2.41 RATIO
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
and heres all of the gm codes if u want to know what came in the car from the factory.
http://www.marshu.com/images-website...-car-codes.pdf
umm u need to find the option codes. usually in the glove box or center console or the door jam. should be a list of three characters, letters or numbers and theres a bunch of em. read thread again and ull see a link on one of my posts. i think thats all the option codes for all the gm vehicles. if u still have the code tag then u should be able to find it. providing u have a posi rearend (turn one wheel and if both turn the same direction its a posi) u can also jack the car up, block the front wheels so the car wont move, block and/or support the car with jackstands so it cant fall, and put the transmission in nuteral, then turn the back wheel one revolution and count the number of times the driveshaft turns. if it turns 3.25 times its a 323, almost 3.5 turns would be 342 about 3.75 turns would be 373. remember this is providing u have a posi rear end. if its a open rearend the oposite wheel from the one u turned would turn the oposite direction if the car is in gear or park and a posi would not turn at all. in order to do this with a open rearend u would need someone on the other wheel turning it the same direction as u so that both wheel turn the same direction and for one revolution. remembering to count the driveshaft revolutions. lol
